Engine
Old 05-25-2010, 01:52 PM
SSCoop's Avatar
Default Engine
This question im about to ask may sound real dumb but can we get these LS4 engines stroked? I would love for my impala to have some crazy power added to it
Old 05-25-2010, 02:17 PM
AlabamaGuy's Avatar
Physically, it's the same block as other LSx engines so yes. It'd have to have a stroker crank (machined to fit) and rods. The topic was actually covered a while back. The real question is why. We are so traction limited it wouldn't be of any real benefit from anything but a a high 2nd gear roll. You'd have to build the transmission, and at that point you'd be better off going with some type of forced induction (from a price standpoint).
Old 05-25-2010, 02:18 PM
indynotch50's Avatar
I've been thinking about this as well lately...
I don't think anyone makes a kit. On that fact, I don't think it would be very feasible. You may be able to modify a 6.0 lsx engine cheaper.
That said, with enough money, i'm sure it's possible. You would have to custom grind the crank and have pistons made with the pin raised further up on the skirt...
My opinion... take a loan and go for it...
Old 05-25-2010, 03:09 PM
SSCoop's Avatar
im thinking about it looking into it more and seeing how much its gonna cost. it would be sweet if it could happen. i would love to have 500+ hp and some mean tq in a car that hardly looks aggressive
Old 05-25-2010, 04:00 PM
AlabamaGuy's Avatar
stroker kits are usually $3,000 assuming you want pistons. $1500-2000 without. Then machine work, pulling the engine, etc.
Old 05-25-2010, 04:04 PM
Sittingmongoose's Avatar
I researched this a lot. We can stroke our engine but it would require a custom crank, and pistons. To do it properly it would require about 8 grand. Which is not at all worth it. When laid next to each other, the ls4 and ls1 cranks are COMPLETELY different you CAN NOT machine down an lsx crank. You need to have a custom crank made.
Old 05-25-2010, 04:11 PM
AlabamaGuy's Avatar
So there's your answer.
Go turbo.
Old 05-25-2010, 04:28 PM
SSCoop's Avatar
looks like i will go the turbo route. what about swapping the 5.3 for a heavily modified 350 cu in? my neighbor has a 88 camaro with lots ot work done to it and it just sits there. the last time it was on the road was back in 2003
Old 05-25-2010, 04:31 PM
AlabamaGuy's Avatar
Don't put a SBC in these cars. there is absolutely NO reason to replace an LSx motor with a small block...
Remember that you'll need to build your transmission, do all the turbo parts, then if you ever want to be able to use it you'll need much better suspension and tires. Don't get in over your head. That's a WHOLE lot of money for a low 12 second car to high 11s.
I looked into that as well however it would require a lot of modification. I would just go turbo it will be a lot cheaper and make a lot more power
Old 05-25-2010, 11:25 PM
SSCoop's Avatar
i guess the right answer is turbo lol. i found a turbo kit online for a little over 5 grand
Old 05-25-2010, 11:35 PM
JDMC5's Avatar
turbo or nitrous. If you want to feel torque then don't be too shy of nitrous
