Heads?
Old 05-27-2010, 06:31 AM
chevySS08's Avatar
Default Heads?
so ive been reading of some of the gxp guys getting heads for there ls4's. my question is are they buying factory heads and porting them theirselves or is there an actual performance head out there? from what chevy has said the ls6 head will not fit the 5.3 ls4 so ya im gettin a little irritated with that, haha, any info will help. thanks
Old 05-27-2010, 07:38 AM
williamGT's Avatar
The 5.3 LS4 has the LS6 heads.
Old 05-27-2010, 08:14 AM
94ss06gxp's Avatar
yup
Old 05-27-2010, 08:52 AM
indynotch50's Avatar
See sittingmongoose's statement a few posts down...
https://ls1tech.com/forums/ls4-front...ng-boring.html
Old 05-27-2010, 11:40 AM
chevySS08's Avatar
so basically the guy at chevy is an idiot then? wow
Old 05-27-2010, 11:44 AM
AlabamaGuy's Avatar
I believe we have smaller valves but the castings are the same. 243s
Old 05-27-2010, 04:03 PM
chevySS08's Avatar
k last question, i need an opinion im going to do a custom exhaust, 2 1/2 inch piping, which do you alls think sounds better the magnaflow mufflers or the flowmaster 40 series? i like both, hate my indesiciveness
Old 05-27-2010, 04:06 PM
AlabamaGuy's Avatar
Don't buy a Flowmaster. Anything but a Flowmaster.
But why limit yourself to those 2 mufflers? There are a ton of choices in the aftermarket.
Old 05-27-2010, 06:28 PM
JDMC5's Avatar
same style heads but smaller intake valve. The bigger intake valve will work but I haven't seen any data that supports a hindrance or gain in power. Yes, you do get the benefit of the bigger valve but the small bore increases shrouding sooooooo. But anyways, stock ported heads will flow pretty damn good, if you're adding a cam get them milled and up the compression.
Old 05-27-2010, 07:32 PM
AlabamaGuy's Avatar
Thanks for backing me up on this, JDM. There is absolutely no point in putting aftermarket heads on these motors without some kind of crazy setup. Our cam and intake don't allow full use of the stockers as it is, and to be honest, we don't have any header choices that will accompany good, high RPM power (ie LTs). Bump compression and let her ride.
Old 05-27-2010, 08:11 PM
Man why hate on the flowmasters? Those were the hot ticket for years. Ha. I tend to like them.
Anywho. He's right. The bad part is they don't make kits for these cars. The good part is that they don't kits and you get to explore different routes. A lot of guys use spintechs.
Old 05-27-2010, 08:40 PM
AlabamaGuy's Avatar
Never looked back either.
Old 05-28-2010, 12:22 AM
JDMC5's Avatar
No problem. Don't quote me on that though, haha.
FWIW, I have a magazine where they put larger valve heads on a 5.3 with a big cam, fast intake and long tubes, the made 458hp..........
