Torx Bolt on Rotors
Torx Bolt on Rotors
Anyone know if the torx bolt that bolts the rotor on the hub is needed? Friend and I were changing the rear rotors and pads and the torx bolt's head completely stripped. I went to Napa and they said just said use a screw extractor to get it out, but they said I dont need to put one back in because its just used during assembly in the factory. Thoughts?
I don't think they are....from what I understand, the torx bolts are used by dealerships to hold the rotor in place so the dealership can turn/resurface the rotors while they are on the car. when i replaced my rotors, i removed them as 1 had stripped and i had to use a drill to split the bolt to remove it.
Yea we just had to drill out the bolt until the head snapped off. All is good now. What a pain in the *** though when you dont have an air wrench to loosen stuff.
