low buzzing noise from dashboard
Old 02-13-2012, 12:15 PM
twomorestrokes's Avatar
Originally Posted by PurpleHaze9414
Does anyone know the fix for the noise in the speakers?
It's normal.
Old 02-13-2012, 01:09 PM
PurpleHaze9414's Avatar
Lol the static noise that is on even when car is off
Old 02-13-2012, 01:25 PM
I know what sound you are referring to. We've owned a few of these cars. It's normal. Open and close the drivers door upon entering the car and it's there, through the speaker.
Old 03-09-2012, 06:10 PM
08GXPGXP's Avatar
Under the steering wheel.. mine does it.. its annoying
Old 03-24-2012, 07:46 PM
2000blkta's Avatar
My car (08 GXP) does the same thing. It sounds as if its coming from the drivers side dash. The sound is like a noisy fan. The car has 54k miles and the noise just started a few months ago. Help !
Old 03-24-2012, 08:33 PM
lVloses's Avatar
Indoor Air Temperature Sensor most likely. You just have to remove the paneling below your steering wheel and the sensor is attached to the panel (look below your ignition and you'll see a small vent, that's where it's at). I couldn't find a replacement for mine anywhere online so I just took it apart and cleaned it really well and then lubed it up. The hum it makes is probably 10x quieter than it used to be.
Old 03-24-2012, 09:10 PM
2000blkta's Avatar
Thanks for the quick reply. That's exactly where the noise is coming from so I think you hit the nail on the head. How do I remove that panel to access the sensor ?
Quick Reply: low buzzing noise from dashboard
