Rear exhaust manifold idea. Work with me here.. guys.
LS2 Corvette exhaust manifold
Stock LS4
I'm thinking of buying the Corvette exhaust manifold and adapting it to our LS4 in order to eliminate the need for the crossover pipe having to dump into the rear manifold. All eight cylinders flowing through one manifold is kinda of restrictive IMHO.
I'd have an exhaust shop fab up a small Y pipe to the stock downpipe. (From the crossover to a section of exhaust pipe coming out of the new manifold)
The stock manifold has the collector in between cylinders number 6 and 8. The LS2 has the collector exiting between 4 and 6. I'd like to think that this would allow a little freedom for an exhaust shop to get creative with a custom Y pipe. I'd like to keep the stock front exhaust manifold and crossover. I'd probably get a Lokar flexable trans dipstick tube to aid in clearance. I don't want DT headers. I like getting creative with stock parts.
What do you fabricators think?
Stock LS4
Give it shot! You biggest issue will probably be clearance to the transmission. The LS4 manifold points more outward to the rear vs. the LS2 that points pretty much straight down.
You might want to conside the early LS1 vette manifolds as well. They are stainless steel and relatively easy to cut up and reshape to clear the transmission:
Here is an inspirational shot (but it took quite a bit of work for the LS7 manifold to clear)...
Ha.. ha! I was viewing those pics that you posted before. The LS1 vette manifolds were going to be plan B. I like the short exit path on the LS2's though. I'm going to take my car into a shop tomorrow with pics of the LS2 manifolds and see what they think they can do.
Green box is the restriction
Basically we have 4 cylinders flowing into cylinder number 8's primary. Lucky for us we have very little valve overlap. GM did a pretty god job though.
I'm not totally... anti. I just don't wanna spend 1000.00 and the group buy thing is going to take awhile. Headers are a little much for our engine till we cam and can get some serious air flow threw a LS6 intake. More compression too would help as well.
I had the headers and I hated the whistle (fixed now I guess?) and the leaks from the clamps and front collector pissed me off. On a stock engine the headers aren't showing huge gains.
I like being different man.. This is why I have a front wheel drive 4 door V8 LOL
Still, I like your plan.
And like I said in the other post, there is a lot low lift overlap in the stock cam. Of course, not so much at 0.050".
Yeah, I don't like how large they are for being shorties. Given the clearance issues and the fact that the O2 sensor is moved farther down stream, I'm not sure the gains are worth the $$ and annoyance cost. The closed loop switching delays get jacked up with the headers, and the old ones didn't clear the better intakes without have to spring for an adapter as well. Granted, since I've completed my swap others have tried different methods with generally better success.
Talked to a fabraction shop today, and the main exhaust guy thinks he can make it work. I have to install the manifold and get the car down there though. (open exhaust?) I'm going to order the lokar flexable dip stick assembly and some flanges. I'll yank the exhaust manifold off next week and we'll see what happens from there.
Keeping my fingers crossed!
Next mod will be getting everything ceramic coated.
