Possible Wiring help
So my car has decided to go ahead and fall apart all at once.
Actually i was surprised my stock battery has lasted this long, 3yr and 52xxx miles. So i had to replace that, my trans has had a few little incident of actting up. Got a bad chatter.... I was at WOT into 2nd gear, then let off suddenly.
When it went to shift into 4th it felt like a clutch chatter but way more intense.
Now on to my electrical issue. I got a "Service Brake Apply Sensor" in my DIC.
Followed by ABS, TC, Stabilitrac, all going off, and no brake lights. Tried the simple change of sensor as it was only a $18 part at carquest. And so any one knows its know as a Brake Pedal position sensor. Rock auto and carquest were the only places i found it outside the dealership. Well after replacing the Sensor the problem went away for a half a day.. I headed out to get grocery's and now its when off again.. So im not sure what the issue it.... I quess im gonna have to chase wires....
I was hoping someone had a wire diagram or any experiance with this problem
