Something weird happens while filling up....
While leaning against my car about a month ago while filling up I noticed that right before the pump turned off my car suddenly dropped about a half of an inch maybe a little more. I thought someone walked up and pushed on the car but there was no one there. Tonight I saw it physically drop about a half an inch. I am sure its due to the weight of the gas but does this mean I am having issues with my shocks? Should I see the back end drop?
Location: Origionally-Winnipeg Manitoba, Currently-Fort McMurray Alberta
i've never seen it drop, more felt it slowly go down when leaning against it..
my guess would be your shocks are NFG...
Mine does the same. Seemsvit gets so many gallons then drops, it's not a slow settle, you can physically see/feel it drop every few gallons. It's kinda weird andvfreaked me out a little when I first got it. It did with the stock and lowering springs.
I feel the same thing. There actually is an engineering term for what you are feeling: stiction. Static friction coefficients are generally higher than dynamic (viscous in this case) friction coefficients. Once you overcome the stiction of the seal between the two cylinders, you can feel the viscous friction take over.
The seal flops in the direction it is being dragged if there is enough force (visualize the windshield wiper dragging back and forth and how it flips over during the direction change). If you lift the car up and then down right before you fill up, which will flip the seal so it is sliding and not dragging, you might not even notice it happening. I'm going to have to experiment some myself...
