Camber Bolts Question
Old 09-01-2011, 09:17 AM
Bryan921SS's Avatar
Default Camber Bolts Question
So at just over 55K on the car I just used up a third set of tires.
I have noticed that the Camber Bolts come in many different levels of adjustability.
For those that have used the bolts what "size" (+/- 1, +/- 1 1/4, +/- 1 3/4) did you end up getting?
Also did you get bolts for the Front and the Rear?
Old 09-01-2011, 09:38 AM
GXP25's Avatar
ACDelco camber kit: ACDELCO Part # 45K18036 More Info {#88914256}
CAM,Steering Knuckle Camber ADJ -; 14MM BOLTS, +/- 1-3/4 DEGREE; 4 DOORS; SINGLE OFFSET
Double check that it fits the Monte.
Old 09-01-2011, 10:03 AM
hazards280's Avatar
Ditto.
Old 09-01-2011, 01:09 PM
LuSe4's Avatar
Not sure which ones you need, but 3 sets of tires is a lot for that many miles.
I am on original RSA's at 43,000+ miles, (and they still have about half tread left on them). I did put in a set of camber bolts (on the rear only) the week after I bought the car and followed it up with an alignment, though.
Old 09-01-2011, 01:32 PM
Bryan921SS's Avatar
Thanks for the info guys, I am going with the ones GXP25 suggested so I can get the most adjustability.
The streets around here are a nightmare, they are either slanted to the right or have serious grooves. That plus the BFGoodrich KDWs and the non-adjustable camber equals a hard life for the tires.
I plan on getting Conti DWS tires once I get the camber in the rear fixed, so hopefully the next set will last 2-3 years.
Old 09-01-2011, 01:37 PM
hazards280's Avatar
Is this your DD?
Old 09-01-2011, 01:43 PM
94ss06gxp's Avatar
Im for sure gonna order these when i get my new tires. I didnt see anyone answer if you should get fronts and rears or just rears? I have the most problems with the fronts wearing.
hazards280's Avatar
Hmm...I wonder why ???
I have just the rears on mine.
Old 09-01-2011, 02:07 PM
LuSe4's Avatar
I did just the rears on mine. My front tires wear evenly across the tread.
Old 09-01-2011, 03:27 PM
Bryan921SS's Avatar
Originally Posted by hazards280
Is this your DD?
Yup, I got to thinking about how many miles I got out of this last set of tires and realized I have only driven the poor girl 5600 miles since December.
I got a set of GP torque stars that I am going to use this winter with some snow tires.
EDIT: For now I just got the Camber Bolts for the rear. Under $30 bucks for the pair on rock auto if anyone is looking for them.
Old 09-01-2011, 07:17 PM
Hawkins04's Avatar
when I did an alignment on my car I did front and rear camber bolts
Old 09-01-2011, 08:16 PM
94ss06gxp's Avatar
my rear tires wear pretty even, the fronts wear on the insides and outsides. tire pressure is good all of the time.
Old 09-01-2011, 08:40 PM
hazards280's Avatar
Now that I think about it, my front tires do have a little wear on the inside. Perhaps I should invest in a set.
Old 09-28-2011, 10:44 AM
Bryan921SS's Avatar
Getting ready to put the Snow Tires on the car and have the camber bolts installed.
After the install while re-alining the car what should the F/R Camber be set to?
As close to Zero as possible?
Old 09-28-2011, 11:19 AM
Dom87SS's Avatar
i used 1+3/4 when i lowered my car and still didnt have a desirable alignment. i was in the "green" but was super close to going out of the good zone. i need to add 4 more all around to the upper bolts next time i get the car in the shop.
Old 09-30-2011, 06:08 AM
Deimos's Avatar
Now camber bolts help and are fairly cheap MOGG number K5330. But did you ,male sure that the normal stuff didnt go bad. IE front end and struts?
Old 10-01-2011, 02:42 PM
GXP25's Avatar
I bought four and the shop was able to put me within the factory specs after being lowered.
Old 10-01-2011, 02:46 PM
GXP25's Avatar
By the way, you're supposed to replace the upper bolts with the camber bolts to get the desired positive camber after lowering.
Old 10-01-2011, 03:38 PM
bigalnash's Avatar
whats the advantage of using chamber bolts if your stock? and can u just ask the shop to put them on after an alignment?.
Old 10-01-2011, 05:16 PM
94ss06gxp's Avatar
Originally Posted by bigalnash
whats the advantage of using chamber bolts if your stock? And can u just ask the shop to put them on after an alignment?.
x2?????
Quick Reply: Camber Bolts Question
