Need help now please!
Old 04-10-2013, 08:08 PM
06_GXP's Avatar
Default Need help now please!
So I'm in the garage trying to make an intake and have lost bolts
and I'm not having good luck.
I think I accidentally pulled a coolant hose and I need to know where it goes because I can't find a spot. It's the hose on the top on the coolant reservoir... it's just dangling. I work in the morning and need to get this wrapped up.
Old 04-10-2013, 09:26 PM
LeadfootDuramax's Avatar
Can you take a pic and post it?
Old 04-10-2013, 09:27 PM
Dom87SS's Avatar
if its the small one it should go to the radiator im guessing as it is the over flow tube.
Old 04-10-2013, 09:33 PM
06_GXP's Avatar
Old 04-10-2013, 09:36 PM
06_GXP's Avatar
I see that the one below what I circled goes to the radiator but the one I circled is very short
Old 04-10-2013, 09:43 PM
IIRC correctly that is just the overflow vent that goes down and does not connect to anything. Its been a bit since I pulled my overflow bottle out. One ran across and ultimately connected where the radiator cap is and the other is a vent that ran down right next to the overflow bottle.
Old 04-10-2013, 09:55 PM
06_GXP's Avatar
Here's actual pics of my car. I didn't see this line until I pulled the air filter box out so I thought I yanked it out by accident but I guess it could be a vent...I've never had a car with a vent. The one that goes to the radiator cap area is connected.
Below is the lower one that goes to the other side of the car.
Old 04-10-2013, 10:05 PM
Moderator
91parkave's Avatar
Literally its just a vent in case you over heat
Old 04-10-2013, 10:06 PM
06_GXP's Avatar
Thank you very much! Glad to know I worried about nothing!
Old 04-11-2013, 08:20 AM
Better safe than sorry.
Quick Reply: Need help now please!
