Motor mounts oh motor mounts
Old 10-12-2012, 10:40 PM
Moderator
91parkave's Avatar
Default Motor mounts oh motor mounts
Finally put in my fortified motor mounts i was suprised at how easy the front was and the rear. I used window weld mixed with about 10%jb weld to increase the strength and longevity. also drilled holes by the studs to get all of the hydraulic fluid which is more like dirty water lol. Filled with poly till it came bulging ot the other side i drilled. I then went around the outside to make sure the rubber was secured to the metal base and attached lock wire from one side to the other to prevent it from seperating under power like 99% of these shitty mounts do. before i did my mounts my alternator pulley sat below the strut tower and now sits up way higher. cant believe it took me so long to do this and wonder why i had issues. All you need for the front and back use 15mm nuts however the rear you will need to take the passenger side CV axle out out to unblot the 4 15mm nuts from the transmission. for the front you will need a swivel and a handy magnetic telescoping wand thingy autozone sells which i used to thread the nuts on just enough to bolt on. will post the pics if you have questions let me know.
The carnage of v8 and FWD and shitty mounts
new mount installed wrapped in reflectix hvac tape
Old 10-12-2012, 10:48 PM
Moderator
91parkave's Avatar
Rear mount process:
If you need sizes----21mm deep socket for strut bolts 15mm for sway bar endlink 36mm for cv nut 13mm for brake caliper.
engine now sitting level again
Old 10-13-2012, 12:58 AM
DavidGXP's Avatar
Very nice write up.
What did you wrap the front motor mount in?
Old 10-13-2012, 03:05 AM
Moderator
91parkave's Avatar
reflectix HVAC heat reflective tape from home depot my logic is keeping the heat
from destroying the integrity of the rubber over time.
Old 10-17-2012, 07:54 AM
1CL3ANSUP3RSPORT's Avatar
We just need a solid mount or poly mount,hopefully someone will make one for us...
Quick Reply: Motor mounts oh motor mounts
