HID lights for '06 SS
I was told that HID lights wont work on our cars unless I get rid of the Auto lights. Can someone point my in the right direction to keep the daytime running lights with the auto lights.
Are you sure you mean wattage? Power consumption is not what should matter, and power consumption can only be calculated not measured (Voltage X Current = Volt Amperes or Current Squared X Resistance = Watts or Sin of Volt Amperes = Volt Amperes Reactive). I'm pretty sure you mean voltage because the current will be dependent on the voltage and resistance (Ohms law- Voltage/Resistance = Current). You would be correct though becuase power would change as you change voltage. The only constant here would be resistance. So as the voltage drops, the current drops, and then based on the power formula the power would drop as well. I dont see how lower V,I and P would decrease the lifespan of anything though. If anything I would expect it to either not turn on at all or burn a little dimmer.
got my HIDs from ddmtuning since they have lifetime warranty and never had problems with the HIDs for 4 years just recently idk what happened that one of my fogs wires got cut off i guess it got snapped on something since my wires were kinda just hanging lol but just got new bulbs and everything is fine
what i did about the drl is just pulled out the DRL fuse located in the fuse box near the battery... problem solved... well also everytime i hopped in the car i turned off auto lights and turned on just my fogs, became a routine thing everytime i hop in auto lights off fogs on traction control off...
Do the daytime running lights operate at a lower voltage? I would assume that if they are not as bright as when in normal mode that they do. Another question I have is do the DTL even turn on with HID lights, if they do do they behave properly (do they stay on, flicker, etc)? It may be that the lower voltage is not enough to produce the arc across the electrodes and by continually trying to create the arc at the lower voltage could be a cause of a lower lifespan. It would seem that as long as a constant voltage is applied for DTL that a simple step up transformer could be used to obtain the correct voltage while in DTL mode if the voltage is AC. There are many factors here that must be considered though, what voltage do the HID lights run at, is it AC or DC, what is happening with the voltage while in DTL mode. If the voltage is DC you could always use a relay that operates at the same voltage and then run a wire off the battery into a NO (normally open) contact off of that relay. Then if the voltage needs to be changed from there add a resistor in series to create a voltage divider. I was also reading that some DTL turn the voltage on and off which also results in a dimmer light. If this is the case then a simple triggering relay with a off delay could be used and then the same idea with a wire off the battery as I stated before. It is very possible to make these lights function properly for cheap, if the above info is provided to me I could get you the correct circuit needed along with a bill of materials. I guess it all depends on how much you really want to make these lights behave properly in DTL mode.
That would make perfect sense too. I'm not real familiar with the theory of HID, but from what I read the most wear on these lights comes from turning them back on before the internals have recrystallized. There are ways to eliminate this though and have properly functioning HID DRL.
Assuming we want to disable the DRL, which kit allows us to have a reliable setup controlled by the manual headlight switch? Meaning, the lights would always need to be manually controlled. To me, this would be a bonus since I always turn off the DRL as soon as I start the car anyway.
I am a big boy and I can turn my headlights on all by myself
Moderator
One of my Silverstars burned out the other day, so I ended up ordering a $30 VVME kit on eBay. Installed em on my lunch today. Went 5000K, and I'm kinda wishing I went 4300K instead. We have 6000K in our Envoy, and I was hoping these 5000Ks would get rid of almost all of the blue, but they are still a tiny bit blue for my tastes. They'll likely lighten up a tiny bit though once they are broken-in a bit, so I'm not too concerned.
I've got some black tape over the light sensor right now, but that is a pretty ghetto solution really. I came across a post at grandprixforums.net that looks pretty promising:
http://www.grandprixforums.net/elimi...rix-22405.html
I did basically that exact same process on our Envoy last year, and it works great. DRL's are disabled, but the automatic headlights still work, and foglights can be turned on separately. The only downside is that the perimeter lighting function is lost as well, which was a bit of a bummer on the Envoy, but worth it otherwise.
