GXP Battery Cable
GXP Battery Cable
I am about the replace the battery cables in my GXP. The battery is leaking acid even though it still works so I am just going to replace the cables.
Getting the OEM cables is really $$$. I was a bit shocked. Is there anywhere you can get these for a reasonable price or is there an aftermarket cable that is correct? Everything I have found non OEM is a universal fit that will probably take some modification. I was hoping someone here had run into this and had some knowledge on the topic.
LS1Tech Sponsor
check newgmparts.com... they're lower than dealers/msrp...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
