Gentlemen, We have headers
well at least the OBX brand they appear to be carbon copies of doug thorleys
http://www.ebay.com/itm/OBX-Exhaust-...-/200937858400
The crossover might not interfere with the throttle body as much, but overall they look smaller. Probably the crap calspeed was talking about "making."
They would probably accept like a 350 offer. Maybe less.
Store Categories
Store home
Exhaust Headers
Throttle Body
Differentials LSD
Exhaust Systems
Fuel Injection
Muffler
Cat Converter & Resonator
Radiator Hoses
Hanger , Clamp & Flange
Gasket
Fuel & Intake
Strut Bar
Turbo & Parts
Exhaust Pipes &Tips
Belts, Pulleys, & Brackets
Spark Plugs & Glow Plugs
Gauge Meter
Sway Bar and SubFrame
Oil Pan
Seat
Flanges
Wheel Lugs & Nuts
Cam Sprocket
Roll Bar
Engine Mount
Gauge Pod
Intake Manifold
Photobucket
This Header Increase Better/Smoother Exhaust Flow At Higher RPM To Generate More Power And Maximum Performance Out Of Your Engine. Great Power Package to Unleashed Hidden Ponies From Your Motor. Get Up To 35% Better Exhaust Gas Flow By Replacing The Restrictive And Inefficient Factory Cast Log Manifolds With These Precision Built High Flow Headers. Great Fitment, Great Quality And Great Price Guaranteed
Collector : 2.5" OD
Primary Tube : 1 3/4" OD
Down Pipe : 3.0" OD
Flange Thickness : 0.4"
Runner Wall : 16 Gauge
Product:
OBX-R High Performance Racing Header
Application:
06 07 08 09 GM Pass 5.3L LS4 Impala SS FWD
05 06 07 08 09 Chevrolet Montecarlos FWD
05 06 07 08 GM Pontiac Grand Prix GXP FWD
07 08 09 Buick Lacrosse FWD
Qualities:
High Performance Track Proven Quality Headers From OBX Racing Sports
Direct Bolt On Set Up Without Any Modification
Dyno Proven, Increase Low End Torque And Horse Power
Great Throttle Response With Great Sound
Utilize Factory Sensors
CNC Machined 3/8 inch Thick Flange
High Quality SUS-T304 Stainless Steel For Best Durability
Comes With OBX Life Time Warranty from Manufacture Defected
OBX Genuine Products Design and Quality of OBX U.S.A.
Store home
Exhaust Headers
Throttle Body
Differentials LSD
Exhaust Systems
Fuel Injection
Muffler
Radiator Hoses
Gasket
Fuel & Intake
Strut Bar
Turbo & Parts
Exhaust Pipes &Tips
Gauge Meter
Oil Pan
Seat
Flanges
Wheel Lugs & Nuts
Cam Sprocket
Roll Bar
Engine Mount
Gauge Pod
Intake Manifold
Photobucket
Collector : 2.5" OD
Down Pipe : 3.0" OD
Product:
Application:
Qualities:
wonder what those dyno/track proven numbers are..
You show me one stock ls4 that these headers are a direct bolt on no modification required item. Talk about false advertising. You tell me how I am supposed to connect those headers to my existing exhaust system without doing some welding to get the downpipe connected.
car manufactures dont really have the catalytic converters in an area where they bolt in... that would make them to easy to unbolt and take off
And I get that. But the headers should be advertised as such and not advertised as a bolt in no modification required item. Having to do the modification is not the issue, it is the fact that they are lieing.
