ls9 Cam Plus dod delete
Moderator
Are you the only one on this forum with a stock trans? lol Like i said before, can't say that the frequent fluid changes are doing anything to help you, but the trans cooler and shift kit are major upgrades on these thing's. Tune just gives you the added bonus of being able to have more control, but that's not something you can expect everyone to be able to understand that doesn't have tuning experience. Alot of people experiment with line pressure in hptuners and wind up blowing a seal out in the trans.
I know we are going way off thread with these transmission post but maybe you could detail your tuning and a refresher of modifications in another post as what it takes to get over 100k out of these trannys without shitting all over themselves. I'm sure it would be of interest to all. Thanks
OK so my other few questions will the ls3 valley cover need modified for ls6 intake ? Do I have a 3 bolt cam or the normal 1 bolt ls style? Can someone list part numbers for everything I could ever need
unless you buy a valley cover already modified to fit the LS6 intake from katech, you will need to make changes to the OPSU port yes.
also saw these up on ebay but they dont have the port drilled for the OPSU, you could probably redrill the hole and attach the adapter plate without any issues.
http://www.ebay.com/itm/LS-Gen-4-Valley-Pan-Cover-Plate-Low-Profile-Carb-Lifter-LSX-LS3-DOD-Delete-55164/131523575934?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D29007%26meid%3Db820a19165ac4ef5bceb73d39f35355a%26pid%3D100011%26rk%3D1%26rkt%3D1%26sd%3D131516729819
#32
