2006 GP GXP jumping odometer
Hey all, i'm having an issue with the odometer fluctuating up and down. While driving at low speeds 30-45 mph, the odometer jumps to 50, 27, 49, 60 etc etc. I looking to change the Automatic Transmission Speed Sensor but not sure if the an input and output sensors and location of them. I've been looking on internet and very little info can be found. Seen one video on youtube of a guy with same issue but no replies as to problem or fixes. Can anyone point me to pics, diagrams or possible diagnosis that maybe causing this.
VSS sensor is right on the end of the trans behind the rear motor mount. The style of sensor can vary but there are two PN's listed all under 20 dollars. Post up which style you have when you pull it and ill post a PN for the correct part. Right behind the metal plate on the pass side in this picture.
