speedmaster 96mm intake manifold swap thread
#81
Yeh been working on it off and on for the past 2 months, almost done with the port work, finished mocking up the MAP sensor port and now i just need to fit it for a gasket. Only thing i have left after that is to order the two gaskets I need and the throttle body and start test fitting again. Hoping to have it installed next month, weather has been goofy so I get some warm days and then it goes freezing cold again.
#86
as long as it seals good, there wasnt enough material there to make a port the same style that ours uses, and to make a oring style that just presses up against the map sensor base requires it to hang out a little bit off the side. Not to mention barely any thread there to hold it in, gotta find the right bolt so it isnt hanging half way into the runner.
#89
Don't know if we need spacers as rails don't have center piece but we mocked up both ways I still got to get the fuel line that connects two rails I though it would come with rails
#92
The kit that came with the rails was more expensive, and wasnt worth the money, didnt trust those made in china rails honestly. If i do have to do the aftermarket rails over the OEM one, it will be a HOLLEY set with the crossover hose. I would like to use the factory rail though for convenience of line placement. I have the FAST spacers I just havent test fit it to see if it props the rail up enough to clear the taller runners.
#96
Originally Posted by spawne32
yes, and initially i was totally against that, for obvious reasons of altering the spray pattern, but after testing the injectors a couple weeks ago with the hats, not even remotely worried about it.
#97
yeh i thought it was gonna be a problem but the spray pattern on our injectors is a 10-15* arc and the fast spacers seem to be built with that in mind. It actually helps the fuel spray at a wider pattern in the cylinder by lifting it slightly out of the port.
