speedmaster 96mm intake manifold swap thread
Old 05-19-2016, 12:15 PM
  #141
rottonj's Avatar
This could be a stupid question but since there is no water thru this manifold could the gaskets be cut and pieced in sections and shellacked in place?
rottonj is offline
Old 05-19-2016, 01:06 PM
  #142
spawne32's Avatar
THat doesnt make any sense, they still wouldnt match up to the cylinder head if you did that
spawne32 is offline
Old 05-19-2016, 02:35 PM
  #143
rottonj's Avatar
It looks like the pic only the end port is off a bit, his seems much closer than yours?
rottonj is offline
Old 05-19-2016, 03:03 PM
  #144
spawne32's Avatar
it is, but it doesnt change the fact that the port is still offset from the head, thats what needs to be corrected, its not the gasket thats the problem.
spawne32 is offline
Old 05-19-2016, 03:35 PM
  #145
rottonj's Avatar
So basically this could really never work. The intake has been ported,he has different heads than you, and many gaskets have been tried and still not really close. This is a boat anchor. This thread should be closed.
rottonj is offline
Old 06-27-2016, 11:20 PM
  #146
nick Ritter's Avatar
No...... it's still better than a ls1 manifold according to hot rod mag. It's a budget manifold we all know you get what you pay for, this shouldn't be hard to port match
nick Ritter is offline
Old 06-28-2016, 08:54 AM
  #147
rottonj's Avatar
Then I wish you well with it. Post back your final results when completed. Good luck.
rottonj is offline
Quick Reply: speedmaster 96mm intake manifold swap thread
