Cam swap
Old 10-21-2015, 08:05 PM
Cocor's Avatar
Default Cam swap
Doing a cam swap in my DD and wondering if anyone knows the stock pushrod length and cam specs? More specifically the base circumference?
Old 10-21-2015, 09:20 PM
spawne32's Avatar
stock pushrods are standard LS 7.4"
Duration @ .050 193/193
Lift @ Cam .482 Non DoD Lobes/.490 DoD Lobes Intake and Exhaust
Maximum DOD lift is .525 @ the cam
the 243 heads are standard LS6 heads, 2" intake valves and 1.55" exhaust valves
Old 10-22-2015, 01:35 PM
Cocor's Avatar
Any information on the base circle around the lobes? Just curious if I need different length pushrods for this swap.
Old 10-22-2015, 01:36 PM
Cocor's Avatar
Don't really have time to pull the engine and measure since it's my daily.
Old 10-22-2015, 05:30 PM
Moderator
91parkave's Avatar
What cam are you upgrading to
Old 10-22-2015, 06:54 PM
Cocor's Avatar
237/242 .605/.610
Old 10-22-2015, 07:53 PM
spawne32's Avatar
Originally Posted by Cocor
237/242 .605/.610
in an LS4??? lmao
Old 10-22-2015, 08:10 PM
Cocor's Avatar
Originally Posted by spawne32
in an LS4??? lmao
Yeah. I'm crazy.
Old 10-22-2015, 08:15 PM
spawne32's Avatar
Yeah. I'm crazy.
you are crazy, the LS4 doesnt have enough cubic inches for a cam that large, not to mention the heads, intake and intake piping dont support flow for something that large. Your valve springs wont support it, nor will your lifters. You will have to take the engine apart to support a cam that large and build the motor up. Not to mention you would need like a 4000 stall and rev to 7-7500 with that kinda duration.
Old 10-22-2015, 08:28 PM
Cocor's Avatar
Lol. I already know what I'm getting into. I'm here asking for measurements.
Old 10-22-2015, 08:30 PM
Moderator
91parkave's Avatar
I know nobody likes nay sayers, however the cam specs you stated would be ideal for a 408 or a wild 383 but daily driven automatic 325 cubic inch your going to make a complete dog of a motor and useless powerband. You need to think 218 to 228 max
Old 10-22-2015, 08:33 PM
Moderator
91parkave's Avatar
If you insist on this cam you need to have a pushrod length checker. To orser the right push rods. Hope to god you got some rockers as well
Old 10-22-2015, 08:34 PM
spawne32's Avatar
Generally speaking, most cam manufacturers wont recommend anything over a 220 duration on either end on any "stockish" 5.3 engine, regardless of RPO code. I've seen 5.3's running slightly larger cams like TSP 224R's and such but even then, they have to be stalled pretty high and rev pretty high and you usually sacrifice a ton of low end that is already lacking as it is on 5.3 engines compared to other LS displacements. OP is essentially building a D series honda engine with 8 cylinders. lol
Old 10-22-2015, 09:10 PM
Cocor's Avatar
No faith.
Old 10-22-2015, 09:19 PM
spawne32's Avatar
No faith.
im all ears on your plan but so far what youve described isnt going to net you anything except a very large paper weight. Over camming a 5.3 is one of the biggest mistakes going around these parts.
Old 10-22-2015, 09:22 PM
tim4daflow's Avatar
237/242 .605/.610
That's a big a$$ cam too much for a 5.3 do you just want it cammed for the sound?
Old 10-23-2015, 09:30 AM
superglide9375's Avatar
too much cocor,but now u have to double and triple ck everything,u gonna have to idle at 1600 lol rethink this my man
Old 10-23-2015, 09:32 AM
by chance did u get this cam free?
Old 10-23-2015, 11:46 AM
lVloses's Avatar
I'm running a cam in the mid 220s with .06X" of lift and I didn't lose much of my low end compared to my old 216/220 cam. I'm also just running a 3k stall. But I agree OP's cam specs are ridiculous.
Old 10-23-2015, 07:03 PM
fieroguru's Avatar
LS1Tech 10 Year
OP's cam is way too big for a 5.3L.
My 224/232 is a little large and peaks at 6800 rpm. It has pretty much the same torque at 2000 rpm as it has at 7000 rpm, and is about 50 lb-ft less than peak (335 lb-ft)... manual transmission, so all pulls are in 4th.
A better matched cam for my particular combo would be a 222/226 .604/.604, and I will likely switch to it over the winter.
Quick Reply: Cam swap
