GXP suspension and brakes
Old 09-12-2016, 06:25 PM
rottonj's Avatar
Default GXP suspension and brakes
Just got thru doing some suspension and brake work on the GXP. I used EBC rotors all around as well as yellowstuff street & track pads. I installed GMPP front bar with Moog poly bushings,outer tie rods,and problem solver spherical bushing installed in new A/C Delco lower control arms. Ran into a snag with the passenger axle popping out , had some help from a bud getting that bitch seated. Car needs an alignment, but its not too bad as I made sure it was close counting threads . This thing is really tight now.
Old 09-12-2016, 11:12 PM
spawne32's Avatar
clean those wheel wells up god damnit!
Old 09-13-2016, 06:46 AM
rottonj's Avatar
Ok I will, when you swap out those **** rubber bushings lol.
Old 09-13-2016, 08:21 AM
Moderator
91parkave's Avatar
Both of yall need to stop lol
Old 09-13-2016, 08:49 AM
spawne32's Avatar
Old 09-13-2016, 09:00 AM
rottonj's Avatar
Damn, that's a serious control arm. I was feeling good about my set up, thanks alot lol
Old 09-13-2016, 04:31 PM
superglide9375's Avatar
wow like those control arms-91 is it a noticeable diff between these and moog regular shape?might be interested in those
Old 09-14-2016, 07:39 PM
rottonj's Avatar
Why do you have an extra loop of hard line that the braided line is connected to? Also what is the reason for the insulation on the braided line? I have not yet got around to the trying the Russell braided brake lines I grabbed last year, should have when I just did the rotors but needed the garage for another project. I purchased some Stoptech STR600 DOT 4 for the flush also. I may just use them on my Comp G, that needs more help braking anyway. Those yellowstuff pads will put you thru the windshield, I love them.
Old 09-14-2016, 08:56 PM
spawne32's Avatar
I believe he mentioned previously that his lines were too short for the GXP brakes and that adding that hard line gave him the room he needed, which is why i was hesitant to do these yet.
Old 09-16-2016, 06:30 PM
rottonj's Avatar
That's a really good solution, I'm fine adding that small extra portion of hard line too. Parkave do you recall the line fitting size?
Quick Reply: GXP suspension and brakes
