Timing cover/ oil pan seal
Old 11-10-2008, 10:57 PM
BigDB's Avatar
Default Timing cover/ oil pan seal
Im adding a cam on my buddies Lt and the seal ripped on the drivers side, I did everthing I could not to be it was stuck in the cover. Now can I just RTV it up in that corner or is pan gasket replacment a must? I have the pan unbolted but its hitting the K-member, I take it Ill have to remove a engine mount and lift or jack up the engine enough?
Old 11-10-2008, 11:07 PM
lt1z28camaro's Avatar
I did the same thing, ended up just replacing the whole gasket, one of those if you're gonna do it do it right things.. You could probably seal it with RTV but, there's always the chance of you putting it all back together and having an oil leak..
I figured with everything apart and tools out might has well just do it right the first time. (Yes, you'll need to unbolt motor mounts and lift motor to drop pan out.)
Old 01-21-2009, 03:42 PM
elias_799's Avatar
you might have to remove the k member bolts and pry down on it. i had too.
Old 01-21-2009, 04:30 PM
I8ASaleen's Avatar
Yep very much agreed, that's what I'm in the middle of. I'm still trying to get the rest of the gasket out and then move the k-member.
Old 01-21-2009, 05:48 PM
moderate Z28's Avatar
I ripped mine too. To hell with taking the oil pan out Im just going to try and use RTV to seal it up.
Old 01-21-2009, 09:05 PM
2XR95Z28's Avatar
I did the same thins and i just bit the bullet and replaced it with a fel pro, you can jack the motor up a few inches with the motor mount bolts out then you can drop the pan the few inches and you can use your hand and just thread the gasket up threw the back... Don't try to skimp on it, its like a 20 dollar gasket, just do it while your there...
Old 01-21-2009, 09:49 PM
myltwon's Avatar
rtv that bitch shut
Old 01-23-2009, 09:20 PM
elias_799's Avatar
how did you remove the metal dowels on the oil pan where the gasket sits?
Old 01-23-2009, 09:56 PM
I8ASaleen's Avatar
For all you M6 folks fyi, you have to loosen all the k-member bolts and then take out the rear 2 to get the pan out. If the pan hits on the crank then turn the bolt in the crank snout over until you get enough clearance.
