lt1 into a 1995 v6 camaro
https://ls1tech.com/forums/conversio...-t56-swap.html
good guy... he just did the swap...and did it very well I must add...
you will need to do a series of steps....pm me and i will give you pointers and stuff like that while you do what you do on your car..these cars are year specific and you cant just use anything when it comes to the harness and little stuff like that...just pm me and ill help you out as much as i can...ive done this swap twice so
OWN3D BY MY PROF!
I plan on doing the exact same thing pretty soon. My 95 is a V6 / A4 car. I have a whole bunch of extra LT1 parts laying around my garage. All I need at this point is an engine harness, PCM, Opti, set of heads, and gaskets. I'm going to use all of the front drive accessories off of my 93, engine out of a 96, A4 trans out of a 97, and eventually an OBD1 PCM and harness.
you need a derent kmember rear end transmission crossmember i belive torque arm bar pcm fuel pump gages theres probly more but cant remember try doing some searches they will help theres also sites out there with lists
