Time to change the steering column...HELP! lol
Ok now I'm going to replace my steering column because it has pretty much sucked ever since I bought the car. Have any of you guys ever changed a steering column out?? This is a '96 t/a. If you guys have, did you guys have trouble with the wiring, etc.??
You will have to make sure the new key is of the same resistance as your old one. If it is not, you will need to get a new key cut with the profile of your new column and the key pellet resistance of your old one. Or, I guess you could swap in the old key cylinder, if it is ok.
