RPM fluctuation at idle in drive or neutral?
Old 12-27-2008, 02:15 PM
NitrousJunkie's Avatar
Question RPM fluctuation at idle in drive or neutral?
Just picked up a 94 Z28 but it has a RPM fluctuation at idle and while in drive, it will drop down then go back up every once in a while, otherwise off idle it runs great.
Any idea's?
Very much appreciate it.
Thanks
-Chris
Old 12-27-2008, 02:17 PM
sdm1234's Avatar
Check for any vaccuum leaks.
Old 12-27-2008, 02:39 PM
ws6t3rror's Avatar
Look for arcs coming through the coil case or grounding problems with wires near coil.
Old 12-27-2008, 08:33 PM
jaywalkersw's Avatar
Mine used to do the same thing...drop about 100rpms then would pick back up. I had a very small vacuum leak. I also changed my plugs and wires at the same time. Not sure which fixed it but I am pretty sure it was the vacuum leak.
Quick Reply: RPM fluctuation at idle in drive or neutral?
