anybody with this roller rockers
Old 01-12-2009, 12:53 PM
crz28's Avatar
Default anybody with this roller rockers
I bought this 1.6 rr through jegs , the problem is they dont clear the stock valve covers, if i gut out the valve covers will it loose its shape and loose oil.
http://scorpionperformance.com/newsi...inum_PicMD.jpg
Old 01-12-2009, 12:57 PM
buffman's Avatar
last I checked Pro-mags were the only clearance issue rockers with stock covers. Even then just straightening the L-shaped brackets is all that is required... If those are wide body also, bend the L-shaped support brackets, then report back.
Old 01-12-2009, 04:58 PM
ss.slp.ls1's Avatar
You may need to clearance them. Cut on the intake manifold side of both valve covers.
http://i187.photobucket.com/albums/x...oject08357.jpg
You should have no clearance problems after that. Make sure that you adjust them properly.
