Getting in time
Old 01-14-2009, 10:03 PM
moderate Z28's Avatar
Default Getting in time
Just want to verify that I will be doing this the right way I dont want to have to tear it back down. Its a 93 LT1 with unvented opti. I just took the timing set off and will be replacing it with a new set. So all I have to do is line up the dots on the cam and crank sprocket, 6 oclock for cam and 12 for crank sprocket and thats it? There is no way to mess up the timing? I have studied the opti very well and I see the flat spots on the splined shaft and how it goes together so that should be no problem. The opti did turn inside a little while I was putting the little splined shaft in but as long as the shaft is in right that doesnt matter right? Thanks.
Old 01-14-2009, 10:10 PM
fergymoto's Avatar
That's it. It's very simple.
Old 01-14-2009, 10:34 PM
ss.slp.ls1's Avatar
Dot to dot, yes.
Spline drive, no idea.
Old 01-15-2009, 06:57 AM
shbox's Avatar
You have it under control.
Old 01-15-2009, 09:59 AM
Thanks and thanks shoebox. Ive been using your tutorial but a few parts are different for my 93.
Quick Reply: Getting in time
