Anyone ever used this setup?
ok just got specs on my new LT1 it going to be a 383 w/a 230/236 .576 Xtreme energy comp cam w/ 1.6 RR's and the heads are gonna be 230 on intake and 175 on exhaust trying to get more info to see if anyone can get me a better guess on the power i will make it is an A4 car w/ 2800 TCI stall with LT pacesetter headers to an X pipe to 3in bullets dumped at the rear end
"230" on the intake doesn't tell us much, other than its marginally better than stock, if that's at peak lift. The XE grind series from Comp are a decent set, although tight on the duration. With your 383, you can go bigger. Maybe look into the XE236, or a custom grind from AI or LE.
But with those heads and that cam, I'd wager between 350 and 375whp.
