ps side valve cover removal
Old 02-11-2009, 08:16 PM
Camaro Jearmy's Avatar
Default ps side valve cover removal
3 weeks of having an lt1 car...97 z and was looking to take off the valve covers. Any tricks in getting the pass side one off without taking off the alternator?
Old 02-11-2009, 08:22 PM
Raven97's Avatar
Is not that hard to take off the alternator, thats what I did, careful with the steam pipe.
Why are you taking it off anyways?
Old 02-11-2009, 08:27 PM
redbird93's Avatar
i think i just pulled off the bracket bar on the back of alternator
Old 02-11-2009, 08:34 PM
my belt tensioner is hard to get to due to the pro charger
i went from 3rd to 2nd trying to hit 4th some guys said they bent pushrods, broke rockers, just want to check it out, and the passengers side looked easier to check first.
Old 02-11-2009, 08:40 PM
lifeisgood's Avatar
the bent pushrods are more common on the lsx engines.
did the car start running weird or something, why are you worried about it?
Old 02-11-2009, 08:51 PM
whenever i very first start it up (cold) makes a lil rattle noise... Also from like 5200 up WOT it cuts out sometimes.
Old 02-11-2009, 08:59 PM
lifeisgood's Avatar
the bent pushrod sounds like a tic not a rattle.....and it cutting out above 5200 would be more into the opti.........did these problems just happen after you miss shifted?
Old 02-11-2009, 09:00 PM
fergymoto's Avatar
I rebuilt a motor recently for a guy that missed a shift. His was pretty bad. See this thread
https://ls1tech.com/forums/lt1-lt4-m...ldnt-look.html
Old 02-11-2009, 09:08 PM
makes sense, the noise goes away after it starts, and every once an a while theres a noise while its idling, but if i give it throttle by hand it goes away past probably 1500. I don't think i turned it that high before i missed. So it was probably there before... how do i go about finding whether its in the opti?
Old 02-11-2009, 09:15 PM
thats nasty. lol...im sure i don't have them issues.
Old 02-12-2009, 07:00 AM
leadfoot4's Avatar
Have you got him back up and running? How bad was the rest of the engine?
Old 02-12-2009, 08:28 AM
fergymoto's Avatar
Yeah he was back up and running in early December. His motor was junk. It had been over heated before so bad that the cylinder heads were junk. They had several cracks, the valve guides had lost their press fit, etc. Had to find him another set of heads to have rebuilt for his motor.
The cylinder bores were worn and the block had to be bored .020". The crank needed turned. The rods were junk, they needed resized so we just put a set of Scat rods with ARP cap screws in it. Had to find a good cam because his had some scuffed lobes and the bearing journals were not so great. It was pretty bad. It was just a stock rebuild to get him back on the road. A quality job though.
Old 02-12-2009, 12:35 PM
leadfoot4's Avatar
I guess so!!
