WHat am I missing in this Cylinder head?
Is there something that should screw into this hole my finger is pointing at in this stock head? I just got them back from LE and there are bolts for the brackets on both sides that go into the other 2 bolts but nothing into this that I can see from what I have assembled so far? same thing on both sides... No its not the coolant tube on the back, been there done that already...
http://shbox.com/1/accy_brkt.jpg
EDIT: After looking at the above picture, nothing goes there at all. The Accessory bracket uses the upper two bolt holes, not that one.
[QUOTE
EDIT: After looking at the above picture, nothing goes there at all. The Accessory bracket uses the upper two bolt holes, not that one.[/QUOTE]
Yeah that's what I just asked about, so nothing goes in this hole at all, no plug needed etc?
