M6 removal
Just pulled mine today. Top driver side trans to bellhousing bolt use about 2ft. of extension. Top passenger use a flex head right at the socket. Pull the other 6 easy as hell bolts. Pull the slave, pull the clutch fork back.
You def. want to pull the trans from the bellhousing first as people have already stated, will make life a lot easier.
On the upper driver bellhousing bolt I will be putting a dent there before I stick this all back together this time, that is the only one where you can't really get a socket on it, its dumb.
