View Poll Results: Which Cam would you rather go with in your car
Voters: 25. You may not vote on this poll
Which Cam would you choose for your car
stock heads?
if so they pretty much make the same power except the gm847 taps out around 5900rpm and the cc306 around 6200rpm
if not stock heads then just go custom IMO unless you find a good deal on one of those
edit: I'd also recommend swapping out those shorties, either of those cams won't be too happy with em
The heads are ported .40 over and im running pace setter long tubes i need to up date stats
Why is nobody voteing..... I guess they dont know about cam's
I'm not saying that OTS cams aren't worth it (they've been proven to an extent numerous times), but in this day and age with the emerging technology behind camshaft grinds from all vendors, big and small, it's something to consider.
One more thing, what does "The heads are ported .40 over" mean?
D
i voted 847 only cuz that was the choices given, but unless you can find one of the two cheap with low miles or NIB in the for sale section, get a custom grind
CC306 --- 230@ .510 INT/ 244@ .540 EXT (1.5RR)--- 112 LSA --- 1800-5800
GM847 --- 234@ .539 INT/ 242@ .558 EXT (1.5RR)--- 112 LSA --- 2000-6800
