Got my motor out and have a few questions
Well first off im happy its out and i took it out the bottom not bad at all. The heads are sent to AI and I am very excited to get them back along with thier 226/234 cam. Well anyways i was wondering it a oil cooler or oil warmer on the motor above the oil filter. I see no need to have it and neither does my dad but my question was has any of you taken it out? I was going to run a bigger oil filter if i could pull it. Also i was going to go with a Spec 3 clutch. Its about the right price range and seems to be a good clutch. Any other suggestions on clutch? Thats all i can think of for now guys. Thanks for any feed back.
sweet i figured we could just wanted to be sure. this is mine and my dads first lt1 build so just checking stuff out and figuring out the do's and donts. also what plug wires and otvc looms you guys recomend. i will be running pacesetter long tubes
You should like the SPEC clutch. I run a Stage 2, and it's a strong clutch for sure, just a little chattery at first... Got a friend with a Stage 2 and another with a Stage 3, both of them Cammed/tuned ls1's with no complaints of them.
