experts needed
experts needed
installing compcam 503 ,right now the car has crane springs 10308-1 ,hardened pushrods,1.7 scorpion rr,s .? is will these springs be enough for the 503 and 1.7,s and will these lifters work with this setup http://cgi.ebay.com/ebaymotors/COMP-...Y-LIFTERS-part no. 850-16,thanks guys..
those springs "should" work. if my math is correct those rockers put your lift at .570 and .578. couldnt get the link to work for the lifters, but the stockers should be ok with that set-up.
Yeah, as long as your stock lifters are ok, they will work fine. I have a CC503 and the Crane 10308 spring kit, with stock lifters in my '97 SS. But I am running Comp 1.6 ProMags. Tabbed 5.3 lift numbers are pretty much correct, I got .569"/.578", which AFAIK the Crane 10308 kit can handle. Don't know what your ideal installed height will be though. I went with 1.8" on my car.
