What do you think of these parameters
Ok, we got the cable and scan software working. HUGE thanks to Bob @ www.aldlcable.com
We went out for a few runs and here are a few things I noticed. Give me your opinions.
10 deg of spark retard max wot, 4-8-10 as rpm climbed
02 sensor mv = 897-910 max wot
spark advance = 38 deg max wot
AFGS 200max wot
AFGS 200max wot
narrowband O2s are not accurate at that AFR but the narrowband O2s will often report 880-920 on a properly tuned car. THIS IS NOT RELIABLE ENOUGH TO TUNE OFF OF.
Ditch the Granatelli. That AFGS number is way low, probably inaccurate reporting, my old L99 would pull more air through a 3" b-body MAF.
Is the knock count climbing or is the retard coming in without current knock count accumulation?
To clarify: this is part of the log from my buddies 94 Firehawk, not the camaro in my sig. It is all SLP stuff except for an aerofoyle, a/c delete, and bigger maf. (not sure on the brand but not granatelli).
Sorry for the confusion.
I will have to watch the log again to answer your question. If I post my datamaster log can you guys see it?
