Harness Swap
Old 03-19-2009, 04:35 PM
cadsmobile's Avatar
Default Harness Swap
I have a '93 LT1 in a Volvo 244. I have tried for some time to get it running and have failed to get it to start for more than a couple of seconds. I'm thinking about tring to swap to a '94-95 Harness and computer from a Caprice. I am I right in thinking the things needing to be swaped to make the newer harness work would be:
-add MAF
-change O2 sensors
-change throttle body
Will my '93 Opti and ignition parts work? Am i missing anything?
Old 03-19-2009, 05:08 PM
ss.slp.ls1's Avatar
-add MAF
-change O2 sensors
What harness are you trying to use now? If it's a harness made for a LT1, I don't see how swapping to a different harness and computer is going to help. I'd keep troubleshooting the current situation if I were you.
Old 03-19-2009, 05:10 PM
96capricemgr's Avatar
Have you addressed VATS?
Old 03-19-2009, 08:22 PM
cadsmobile's Avatar
I'm using a factory '93 harness and I've been working on it for months. I got the car as a project with the engine installed and the harness somewhat modified but not running.
Yes, the computer was supposed to be tuned to have it disabled. I also tried a bypass chip and it made no difference.
I thought starting out with a fresh start might help. I have tried a new Opti, computer and re-wird it 3 times all with no luck.
Quick Reply: Harness Swap
