Valve covers
Proform 141-131 black or 141-130 polished, I run the black ones myself. Licensed GM parts. Leave out the baffles if you have rr.
you took your pcv valve off of your intake manifold? Or are you talking about the cvc that is just the elbow that comes off of the back of the passenger side valve cover? and if this is the one that you are talking about did you just cap it off at your TB? i hadd done this with the factory valve covers and just put a breather filter on there and it ended up blowing oil out of it all on to my headers.
Guest
Posts: n/a
I do not run a PVC/CVC at all....for crankcase ventilation I run a single breather on the front of the passenger valve cover. I have capped the TB inlet.
I have had zero issues with blowing oil out of the breather. If you do, you can run a catch can off the valve cover and vent the catch can to atmosphere
