help! car dies
Old 04-08-2009, 07:09 PM
ihaterice's Avatar
Exclamation help! car dies
my car will just stop running after it warms up. for example i leave for work in the morning when it is cool out and i have no problems. but later on in the day when i go to leave after the sun has been shining on my car all day it will die shortly after running. it has to have something to do with under hood temps! after the car dies i can usually not get it to start for another 2-3 hours after it has been sitting. any ideas?
Old 04-08-2009, 07:22 PM
ss.slp.ls1's Avatar
I'd check:
-ICM
-fuel pressure
-Waterpump temp sensor.
Old 04-09-2009, 09:23 AM
ihaterice's Avatar
waterpump temp sensor might make scene. i know my car has had cooling issues. last time i checked my fuel pressure i was at about 43psi on the rail. so i would think that is fine. and when it dies and i try to start it i can smell raw fuel outta the exhaust.
Old 04-09-2009, 11:11 AM
ss.slp.ls1's Avatar
Check the ICM yet?
Old 04-09-2009, 06:50 PM
ihaterice's Avatar
i have not, heard that is a common this with these cars. is there any easy tests to perform on it? other that taking it out and trying a new one?
Old 04-09-2009, 07:03 PM
ss.slp.ls1's Avatar
Not really. Autozone has a machine (only a few locations have the right cable) to test the ICM. Your best bet is to try a known working one. You should also perform the ICM cooling mod at the same time.
Old 04-09-2009, 07:15 PM
ihaterice's Avatar
alright, and what is the icm cooling mod?
Old 04-09-2009, 07:21 PM
ss.slp.ls1's Avatar
Take the double studed bolts that hold the ICM to the head, instead of bolting the ICM flush with the head, tighten the bolts into the head, then slip the ICM onto the bolts and use two nuts to tighten the ICM down. See pic (I didn't use any washers though, just used the doubled ended bolts):
http://shbox.com/1/ICM_coil_studs.jpg
Old 04-09-2009, 07:27 PM
ihaterice's Avatar
ok thanks for your help, im like 99% sure that will be my problem... just looked at them through napa, looks like $154 do you know anywhere it might be cheaper?
Old 04-09-2009, 07:34 PM
ss.slp.ls1's Avatar
I don't know, see how much it is from your local dealer, I like to stick to GM parts when it comes to vital sensors.
Old 04-09-2009, 07:38 PM
ihaterice's Avatar
very true! thanks again for your help!!
Quick Reply: help! car dies
