Anyone run a shorter belt instead of ac delete pulley?
Just need to know if anyone does it and if there are any problems. Also what size belt. I am swapping a LT1 into a 65 Skylark and am not using the ac or heater. Oh that reminds me. How do I recirculate the coolant that would normally go to the heater core back to the water pump since i'm using a heater.
had this
I was running A/C delete pulley and if you go to a good parts store, you should be able to find the right belt. If I remember right, the pulley that I used was off a mid 90's Caprice and we just used the serpentine off that. Not completely sure though, that was done 4 years ago.
Whether you need a different length belt or not depends on what vintage the original pulley was on your a/c compressor. There were two different sizes used over the years. The belt should end up being a 635-637 or 642.
For the OP, you now realize that you cannot run without at least an a/c delete pulley.
The heater hose nipples can be just closed off or you can loop a hose between them. Some people pull out the pipes, thread the holes and screw in a pipe plug.
