Im I using the wrong oil filter ? Mobil 1
Old 04-27-2009, 05:25 PM
killagt's Avatar
Default Im I using the wrong oil filter ? Mobil 1
M1-111 MOBIL 1, for my 97 z28. its this correct oil filter ? thanks
Old 04-27-2009, 05:29 PM
Moderator
BizZzatch350's Avatar
I have used the MI-302 in mine.
Old 04-27-2009, 05:48 PM
lt1-xjs's Avatar
That's what it calls for. I also run the M1-302 which is a longer version if you have the room.
Old 04-27-2009, 06:12 PM
camerory's Avatar
Yes, that sounds correct. Are you asking because the one you took off was a different size?
Old 05-02-2009, 12:02 AM
killagt's Avatar
yes, m1-111 I bought seem smaller then other. that why I ask, im i guess im using m1-302 next.
Old 05-02-2009, 02:58 PM
killagt's Avatar
One last question before I ran out and exchange 4 mobil 1 oil filter ( my local store manerger sold me $5 each ), I was in autozone today and compare between m1-111 and m1-302, 302 is 2 time longer then 111, just wonder any benefic, or will it make my oil pump work harder ? thanks
Old 05-02-2009, 04:15 PM
gregrob's Avatar
The added capacity is a good thing to prevent starvation, in a high performance engine flow is the most important aspect of a filter. I like the oversized k&n better than the m1. The number for that one is hp3002 IIRC
Quick Reply: Im I using the wrong oil filter ? Mobil 1
