MSD 6AL troubleshooting
Has anyone used the MSD 6AL Ignition Control and had the engine code P0300 for a random/multiple cylinder misfire??? I'm trying to figure out what is causing this! I have replaced the distributor, cap, rotor, plug wires, plugs, and still nothing has changed! Anyone had this issue???
I'll check. I know it says random/multiple cylinder which tells me it is more than one cylinder doing it, and it is not a constant miss, it is random and I can feel it, its very sparatic...Could that still be a cracked head??? I hope not, these are expensive heads!
Well the "Random/Multiple Cylinder Misfire" code went away somehow, and now its just a #5 Cylinder Misfire. I have had a lot of problems with that cylinder's spark plug wire burning out on my header for a while. We put a piece of kevlar on it to try and stop it, but apparently it didnt work, I think that is my problem...I HOPE...that is my problem.
