How is the install on EWP and UDP?
Old 05-07-2009, 10:04 AM
lt1noob's Avatar
Default How is the install on EWP and UDP?
ive been thinking of doing these since my car is no longer a DD but how are the installs? im afraid of doing the UDP because i dont want voltage problems, but i dont have a system so im thinking ill be fine. and how does the ewp get wired up etc? also, for the udp, which should i get? thunder racing has a ASP 34% crank pulley for 80$ and looks decent from the pics, may order that as well as my ewp from here. tell me what you guys think.
Old 05-07-2009, 10:22 AM
bigj2717's Avatar
The ud is really ez takes like 15 minutes. I have a huge system and i didnt get the alternator pully and i have no problems. The ewp isnt bad either the hardest part i thought was hammering out the impeller shaft. You can buy the wiring harness from summit or just make one yourself like i did its just a regular relay and fuse or circuit breaker
Old 05-07-2009, 10:26 AM
TDavanzo's Avatar
I would recommend buying a painless relay kit for the electric water pump. If you are interested I actually have one for sale. I'll PM you with a price and a link to the for sale thread.
Old 05-07-2009, 10:58 AM
lt1noob's Avatar
i cant find the harness for the ewp, even on painless's site?
Old 05-07-2009, 12:16 PM
lt1noob's Avatar
seems for the pulley, i just need to make sure i get the alternator overdrive pulley as well? so the crank udp, alternator odp, and belt?
Old 05-07-2009, 04:59 PM
I8ASaleen's Avatar
I wouldn't do both. The alternator pulley would cause voltage problems with the added draw that an EWP would put on it. I didn't do the UDP because I relocated my battery to the back and even with good wiring it still has voltage trouble every now and then.
Old 05-07-2009, 05:33 PM
bigj2717's Avatar
You can get the wiring from summit. I just did the crank pully and belt and left the alternator alone
Old 05-07-2009, 10:06 PM
lt1noob's Avatar
the alternator it says is an overdrive, was guessing it makes up for the lost voltage from the crank udp? yeah im thinking i may just stick will the pulley and stay away from the ewp until later on if i make it a track car.
Quick Reply: How is the install on EWP and UDP?
