Cam Istall/Rear Gears Swap??
I apologize if this has been covered over and over, but I can't find it in search right now...
Anyone know of a reliable source on how to do a cam swap on an LT1 WITHOUT pulling the motor out, and also how to do a rear end gears swap??? I am going from 3.73's to 4.10's.
http://shbox.com/ci/cam_removal.html
http://shbox.com/ci/cam_install.html
http://shbox.com/ci/valve_spring_swap.html
I haven't seen any guides for a gear swap because it's kinda tricky and you can ruin your rear end if you don't get all of the spacing correct.
