Replacement Fuel Pump?
I need a new pump... i dont have a lot of cash but i need a good kit... Something to drop in w/e and modification.. Ill be doing the trap door method.. Looking to spend aroun 100-150$
will it be to much for a stock motor? I heard that you need to splice wires and stuff with that maybe im wrong. what about a walboro 255lph?
Just as my post says, the Racetronix kit uses a Walbro 255lph pump. You don't have to cut and splice any wires. You do, however, have to trim the fuel bucket a little. There is a write-up somewhere around here that I followed, install is a snap, especially if you do the trap door method.
