Head gasket replacement
Just blew a head gasket on a 93 corvette. What all do I have to remove from the engine to get the head off? What gaskets am I going to need? Its the passenger side.
plus you want to remove both of them because of the steam lines. You can not get in there to remove them off the back of the heads. If you pull one out and then try to disconnect it you will bend your steam line. Also if you try to get a wrench in there to remove the bolt YOU WILL strip the head due to lack of room.....ask me how i know you are already going to have to replace the one steam line gasket and they come in a set.
Plus when you buy new head bolts...and you will have to because if you reuse the factory ones you run the risk of them snapping, they come with the bolts for both heads.
Just take everyone else advice and replace both of them. We know these things due to error that we have done ourselves or from others mistakes. It will be assurance to replace the other one anyways.
w/p can stay on.... Its hard to rememebr off the top of my head but mostly the whole top end must come off.. Intake and all... Just use a breaker bar to break the bolts loose.. DO NOT and I repeat DO NOT use an impact gun on head bolts.. ALWAYS use hand tools
The rear head bolts are not that difficult to remove. Especially since it is in a vette. You should be able to leave the WP on, but it will get in the way since the intake is right there. I would recommend draining the engine through the drain on the engine itself after you have drained the radiator itself. This will keep the water from pouring everywhere when you take the head bolts out.
But drain coolant, remove belt, remove Acc. bracket(makes things a little easier) remove WP (recommended), remove intake, remove valve covers, remove heads.
I might have missed a thing or two
