LTX Shootout results
LOL! Best was a 12.2 at 116 with a 1.9X 60 ft. Terrible.
My clutch was fucked also. Loading onto the trailer we found the Hyd line from the master to slave had a hole & was leaking, and the pedal is way off, almost kept me from racing but I said **** it and ran anyways. I just pulled up the seat and put the clutch to the floor every shift after my fist 2 qaulifing runs went bad.
Get that rear suspension upgraded and those 60s should drop like a rock.
The TA is relocated already. Currently it has the TA and relocation, LCA, PHB, SFG,STB and removed front sway bar on stock WS6 suspension.
It Needs shocks/springs ,relocation brackets, k-member a-arms, and it will hook way better. Maybe a Drag bag???
Tires were at 16psi
It will go bottom 11s soon!
Tires were at 16psi
