LT1's with nitrous. What coil are you running?
Old 06-01-2009, 09:50 PM
pyro719's Avatar
Default LT1's with nitrous. What coil are you running?
I'm using an autozone stock replacement coil right now and thought an aftermarket coil like an msd blaster might help my ignition when spraying? I Believe I'm getting spark blow out in third gear?
Old 06-02-2009, 05:01 AM
94FBIRD's Avatar
I run a stock GM coil. I think you'll need an MSD box for greater spark intensity. I do and have never had a problem. Plus the multiple sparks at low rpm help keep the colder plugs from fouling.
Old 06-02-2009, 08:32 AM
pyro719's Avatar
Im running the mallory 685
Old 06-02-2009, 12:40 PM
robsquikz28's Avatar
there a hundreds of people using a stock coil with nitrous and running 10s so its capable of producing the spark you need
Old 06-02-2009, 09:48 PM
94FBIRD's Avatar
Hmmm, maybe the Autozone coil is a weak Chinese-made unit? If so, could try the stock GM one.
Quick Reply: LT1's with nitrous. What coil are you running?
