I should probubly know this
Old 06-20-2009, 08:15 PM
93TAJ.C.'s Avatar
Default I should probubly know this
I was just wondering if headers make a little noise. I have pasesetter lt's with 3" ory on my 1993 lt1. Ever since i put em on i hear what sounds like an exhaust leak, but they dont seem to be leaking at all, and they have been on for about 3000 miles. I don't know anyone with lt's so i cant compare. I used felpro header gaskets too.
Old 06-20-2009, 08:29 PM
Z28Camaro30Ann's Avatar
are you sure it is at the header??? Did the exhaust get a good seal at the collectors? Are all the bolts nice and tight? Check the welds where the tubes hit the collector as well, sometimes they arent perfect or break loose...make sure your O2 sensors are flush and tight, and do you have emissions? If so check to make sure all is nice and tight. If not but the headers do make sure they are blocked off.
Just to clarify, I am not trying to insult your intelligence, just covering the basics.
Old 06-20-2009, 08:39 PM
93TAJ.C.'s Avatar
lol I never assume an insult. I'm not totally sure where the sound is coming from, but i do konw all the conections are tight.
Should it be as quiet as stock?
Old 06-20-2009, 08:45 PM
It shouldnt make any difference at the engine...it will sound throaty at the exhaust, but as long as everything is set-up right and tight, it should be nice and quiet...what kind of noise are we talking about exactly and how loud is it?
Old 06-20-2009, 08:57 PM
Smokinlt1's Avatar
Find a shop with a smoke machine and ask how much it'll cost to see if you have any leaks. Those things make finding leaks so easy, too bad they cost so much.
Old 06-20-2009, 08:59 PM
I should have thought of that!! Good call Smokin! It costs a few bucks, but its worth it to find a pesky leak...I second that!
Old 06-20-2009, 10:07 PM
moderate Z28's Avatar
In my experience headers always make a small ticking noise but I love how it sounds.
Old 06-20-2009, 10:12 PM
wrd1972's Avatar
Assuming you dont have leaks. LT's in general, LT's make a bit more noise under the car than your manifolds or shorties.
Old 06-20-2009, 10:27 PM
shbox's Avatar
A faint ticking is normal for a car with headers. The thinner pipes deaden less sound than the stock cast iron manifolds.
Old 06-20-2009, 10:39 PM
Noah's95z28's Avatar
Headers always seem to leak, if not right away they will eventually. They seem to sound like lifters ticking to...........
Old 06-21-2009, 09:45 AM
I didn't notice a difference in sound when I installed my Dynatech's...but that could be because I wass so damn hung up on how AMAZING the exhaust sounded after I installed the LT's lol
Old 06-21-2009, 06:14 PM
leadfoot4's Avatar
Originally Posted by shbox
a faint ticking is normal for a car with headers. The thinner pipes deaden less sound than the stock cast iron manifolds.
bingo!
Old 06-22-2009, 12:55 AM
93TAJ.C.'s Avatar
Exactly what i was thinking, thats all it sounds like to me, just a slight ticking noise. I still have stock rockers so it's not them either. I think i may have a small leak at the y pipe to the cat back, but nothing major.
Old 06-22-2009, 12:59 AM
The Manalishi's Avatar
Get a spray bottle with soapy water and spray the connections heavily and you will see if its leaking. Do it when the car is cold at startup. If you see bubbles its leaking.
Quick Reply: I should probubly know this
