Correctly Aligning Crank/Hub and Pulley
1996 Vette LT1
Since this is only the 2nd LT1 I've built and because I can't find Volume 2 of my FSM set, I want to check my memory on the alignment just to be sure I do it right.
When installing the hub, I'm supposed to align the DOT on the hub with the keyway groove in the crank snout. then when installing the damper/balancer/pulley, I'm supposed to alight the cast-in arrow with the hub's DOT.
Am I correct? I want to prevent any chance of a vibration in my son's 96 LT1Vette.
Thanks for any help.
Jake
1996 Vette LT1
Jake
1996 Vette LT1
Jake
1996 Vette LT1
Jake
