Freeze plug size for back of water pump (using Elec WP).
Old 07-02-2009, 07:15 PM
ss.slp.ls1's Avatar
Default Freeze plug size for back of water pump (using Elec WP).
I got a new engine with a double roller timing set already installed. The timing cover already has a freeze plug installed for the WP gear drive.
I have a WP housing with the guts removed already. It appears that it needs a freeze plug in the back...but what size?
I tried searching, nothing helpful. This will be my first Elec WP install...
Old 07-02-2009, 07:30 PM
RamAir95TA's Avatar
Your best bet might just be to measure with a dial caliper and grab a few from the parts store.
Or, maybe you'd have luck calling up CSI and/or Meziere and just ask them. Tell them you didn't receive a plug with your kit and you need the right size.
Old 07-02-2009, 08:13 PM
strokin93z's Avatar
1 1/4" i believe is the size. i would just take it with you to the part store and see size it up.
Old 07-03-2009, 12:36 AM
airfix's Avatar
I just went to the local auto store and the matched one up.
Old 07-03-2009, 11:16 PM
MattSapp95_T/A's Avatar
Yea they should be able to match it up pretty easy at any local auto parts store...i put a little rtv around it too just to make sure it doesn't leak
Old 07-06-2009, 06:53 PM
edunegan's Avatar
got mine from the guy that does my machine work we used a metric size i believe
Quick Reply: Freeze plug size for back of water pump (using Elec WP).
