About to give up on tuning
Ok I am going nuts here.
I have LT1Edit with 2 Vins both full versions came with the car.
I have the data cable that came with the car, the OBDII connector (I have a 95) the AKM connector and then a serial to parallel. I have no serial port.
I have tried the following:
1) Serial to USB, will not connect. I did select the right come port this is the same connector I used with Megasquirt no problems.
2) Parallel right into the parallel port (I had to get a male to male connector obviously) nothing.
3) Parallel to USB (Again using the male to male connector) nothing.
I thought I was making progress as the PCM Comm and Prog one's will claim to be connected on Com 3, but nothing else.
I try to use LT1edit and it reads no vin just as the mentioned programs. I try to edit the system and it gives me a run time 11 error and crashes.
I was thinking about buying tuner cats but now I am just pissed and want to kick it out the damn window. Tuner Cats looks nothing like Megasquirt either and frankly these seem to be different animal's by far. I am lost and frankly pissed that I seem to have so many problems with just connecting not to mention getting the chance to try and figure out what the hell I am doing so I can tune.
Can anyone help me here.... or just take the laptop everything and I will buy a mail order tune? I am going nuts here.
(Sorry its been a long night)
