big hp guys, what cia are you using
Old 07-17-2009, 09:57 PM
Kory 88Iroc Lt1's Avatar
Default big hp guys, what cia are you using
I think that I have about reached the point where my current air cleaner set up is probably costing my power. I'm running a modified 3rd gen dual air cleaner set up. My current set up should be in the neighborhood of 440whp (AI heads/cam/intake ect)when everything is sorted out. I would like to know what you guys are using preferably cars over 400whp and trapping 118mph or higher.
Also if you don't mind listing what spark plugs/heat ranges you are using that would also be helpful.
Thanks,
kory
Old 07-17-2009, 10:07 PM
Moderator
JasonShort's Avatar
I've always found the K&N FIPK to work best on my high hp NA motors.
Jason
Old 07-17-2009, 10:20 PM
I'll take a look at one. Do you happen to know what they flow?
Thanks,
Kory
Old 07-17-2009, 10:46 PM
RamAir95TA's Avatar
Factory ram air, Fernco bellows, TR55s gapped at .035".
Old 07-17-2009, 10:51 PM
Thanks, I wish the 3rd gen ss hood was a true ram air I would buy one. ram air would be the way to go.
Thanks,
Kory
Quick Reply: big hp guys, what cia are you using
